5 members (Jensen1960, +8Rich, ScotiaSteve, moggin, Ian Wegg), 222 guests, and 61 robots.
+8Rich 79
DaveW 51
Topics49,864
Posts837,580
Morgan110 #682751 12/01/21 07:36 PM
Ian, from your build year I suspect the steering rack gaiters as per Richard's photo above, the maker of the OE rack clearly use some inferior quality rubber/part as I'm on my second set, It's getting annoying as next time will be an MOT fail at my cost mad
Morgan110 #682771 13/01/21 06:45 AM
Richard,
I have just changed the rubbers of an 2 year old steering rack with the same problem. Very small cracks in the rubber.
Stefan
+4
+8
ARP4
Morgan110 #682787 13/01/21 08:45 AM
Just to add the Car Builder Solutions universal gaiters I linked to above are easily chopped down to the size to fit. I offered these to my dealer on the understanding he would fit either MMC warranty one's or mine dependant on which was the more supple and therefore less likely to split again. He chose mine, the CBS ones.
The gaiters can leak from the ends where their lips fit into narrow grooves in the racks main body. They are secured with plastic cable ties which can be replaced by more durable steel ones. Cain at Wolf Performance suggests these ties are wider than the main body grooves though, so do not exert pressure to give the best seal. He advocates narrower ties to better match groove width, also allowing better location.
I would suggest that even if gaiter(s) appear intact when attempting to cure a leak, they be replaced then as its only a matter of time before the less compliant OE ones will split, on recent cars at least. This would have saved two independant warranty claims on my car never mind the inconvenience.
SimonH #682877 13/01/21 02:37 PM
Originally Posted by SimonH
It could be a number of things:-
Coolant- although the factory tend to use red antifreeze
The lubricant (semi fluid grease) used in the steering rack- It can leach past the rack gaiters
The under seal the factory apply liberally over everything, its a yellow/gold colour....if it has been sprayed on the radiator it will melt when its hot and drip....
Hi Simon
I think you may be correct about the underseal as it is the correct colour. Also there was not a lot of it and today on inspection seems to have stopped.
Elaine
2020 Morgan Plus 4 110 Anniversary. “Bamm-Bamm”
Volvo S60 R Design T5 “Pebbles”
Ray #682879 13/01/21 02:40 PM
Originally Posted by Ray
Is it power steering fluid?
No power steering on the car so not that, but a good suggestion.
Elaine
Morgan110 #682880 13/01/21 02:41 PM
Many thanks for all your replies
And will monitor it
Ian
Morgan Plus 4. 110 Anniversary
Volvo S60. R Design t5 2020 70 reg
Ray #682898 13/01/21 04:49 PM
Whats power steering in that one of though new inventions Morgan have come up with in the last few years
Very much in the dog house, could be up for rehoming
Morgan110 #682915 13/01/21 05:33 PM
MMC use an electric assist motor on the column (so no fluid involved) even if it did have PS
Underseal on a 2020 Mog will be black & waterbased since MMC set up their own treatment bay a few years ago (once it's cured it's a bu66er to shift and does not dissolve in solvents or melt easily
