0 members (), 416 guests, and 82 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
#683497 16/01/21 03:47 PM
Ray Offline OP
Hi.i need help please.Does anyone know if there is a second fuse box
On a 2007 Duratec 1800 4/4.
I was fitting Peter's new wiper blades.But unfortunately
When I started them .one wiper jammed After getting
Clearance on the wipers. I found the wiper and washer
System is dead.Ive checked the fuse box under the bonnet
All the fuses seem ok.Is there a relay or online fuse to look for.
Thanks Ray.
Ray #683500 16/01/21 04:14 PM
On my 07 +4 there was also a fuse box under the dash, passenger side I think.
Cheers
Ray #683503 16/01/21 04:29 PM
According to wiring diagrams in the 2006 to 2014 parts book there is a 20 way fuse box. Fuse 8, 10 amp is shown for Wipers on all variants. Suggest pulling that one out and checking for continuity with a multimeter.
Ray #683505 16/01/21 04:48 PM
Ray Offline OP
Thanks boys, just had a look with a torch there is another fuse box above the transmission tunnel I'll check them tomorrow. Looks a bit fidly . But has to be done.
Ray #683508 16/01/21 05:02 PM
Hi Ray,
Yes, you’ve found it. Might help to use a mirror and a fuse puller or small pair of long nose pliers.
Watch your back!
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Ray #683543 16/01/21 07:51 PM
Black Rat
Black Rat
Try the plug under the bonnet passenger side near the bulkhead, a constant problem.
Keith
2013 narrow bodied + 4 Ruby.
SALMO #683546 16/01/21 08:08 PM
Ray Offline OP
Originally Posted by SALMO
Hi Ray,
Watch your back!
. Looking forward to some new yoga moves. scared
Ray #683612 17/01/21 12:31 PM
Ray, my fusebox is in a similar place. Being a supple athlete helps get at it! NOT!
My blade fuses have contacts For testing in situ with my multimeter so a bit easier. They are standard blade fuses not mini size. I have a few spare and a good mixed pack of the smaller mini blades you can have if needed.
Ray #683615 17/01/21 12:38 PM
I wouldn't rely on testing for blown fuses in situ. Random paths in connected circuitry could distort reading.
Ray #683621 17/01/21 12:50 PM
Fuses can develop hairline cracks which test OK, but under load will heat up and break the circuit.
