Topics49,852
Posts837,444
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Hi.i need help please.Does anyone know if there is a second fuse box On a 2007 Duratec 1800 4/4. I was fitting Peter's new wiper blades.But unfortunately When I started them .one wiper jammed After getting Clearance on the wipers. I found the wiper and washer System is dead.Ive checked the fuse box under the bonnet All the fuses seem ok.Is there a relay or online fuse to look for. Thanks Ray.
Posts: 614 Likes: 22
Posts: 614 Likes: 22 |
On my 07 +4 there was also a fuse box under the dash, passenger side I think. Cheers John
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
According to wiring diagrams in the 2006 to 2014 parts book there is a 20 way fuse box. Fuse 8, 10 amp is shown for Wipers on all variants. Suggest pulling that one out and checking for continuity with a multimeter.
Thanks boys, just had a look with a torch there is another fuse box above the transmission tunnel I'll check them tomorrow. Looks a bit fidly . But has to be done.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Ray,
Yes, you’ve found it. Might help to use a mirror and a fuse puller or small pair of long nose pliers.
Watch your back!
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 5,440 Likes: 131
Black Rat Charter Member
Posts: 5,440 Likes: 131 |
Try the plug under the bonnet passenger side near the bulkhead, a constant problem.
Hi Ray,
Watch your back! . Looking forward to some new yoga moves.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Ray, my fusebox is in a similar place. Being a supple athlete helps get at it! NOT! My blade fuses have contacts For testing in situ with my multimeter so a bit easier. They are standard blade fuses not mini size. I have a few spare and a good mixed pack of the smaller mini blades you can have if needed.
I wouldn't rely on testing for blown fuses in situ. Random paths in connected circuitry could distort reading.
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Fuses can develop hairline cracks which test OK, but under load will heat up and break the circuit.
