2 members (+8Rich, Pittsartist), 192 guests, and 57 robots.
+8Rich 76
Topics49,863
Posts837,544
Harrylime #68457 17/09/11 07:50 PM
barry Offline OP
Hi .,Thanks for all your replies,I think Ill use it for a few months (as suggested by frank4x4)to see if I get used to it,before I go down the road of altering springs ect.Ive regreased the kingpins and they seem OK..
Im probably too used to the soft suspention on my Volvo.
Thanks again..
Barry
barry #68460 18/09/11 06:38 AM
Barry, the subject has been covered well by all the posts above; therefore, I will simply welcome you to Talk Morgan.
Simon #68471 18/09/11 08:19 AM
Welcome Barry!
Trad Mog suspension is 'firm'. You will certainly find it stiffer than any Volvo road car (and probably that of a race car). If you have standard springs you will very likely have 'falling rate' suspension.
Both the Rutherford set-up and soon to be new factory suspension should be rising rate. One of the easiest ways to reduce the present falling rate set up is to fit shorter main springs, so allowing a little clearance between the rebound spring and the sliding axle. When you check your suspension later I bet you will find neither spring has any clearance, thus the spring rates are additive until the main sprin is compressed sufficiently to clear the rebound spring, when the main spring rate is the only one that applies.
Ask for a chap by the name of Peter Ballard on MogTalk - he will happily explain it correctly, with as much maths as you can handle, should you so wish.
But as Frank says - drive the car for a bit before changing anything - and enjoy it! grin2
Cheers,
