1 members (Saxonian),
271
83
Topics49,849
Posts837,424
Posts: 1,490 |
Have you found out what the problem was that caused the smell of petrol yet Ken? It would be nice to know before the whole system gets replaced if you go for Emils "Delux" system.
Nope. So no idea. Since I changed out the lines and clamps, and there’s no sign of fuel other than the smell emanating behind the air cleaner I’m still at a loss. The only insight I’ve gained in this thread I’d that maybe it’s microscopic and coming from the pressed fuel fittings.
The Original Ken 11,000 miles.
2014 BMW R9T 2005 Saabaru 2005 Saabaru
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Try some UV dye in the fuel?
Steve Late 2012 M3W
Posts: 1,490 |
Good idea.
Posts: 1,490 |
The past four or five drives... there’s been no smell. So now I’m really confused as to what cause might be inconsistent.
A leaky injector might give you those symptoms, as the fuel system stays pressurized for some time after shutdown. If the leak was caused by a tiny bit of debris that was later dislodged, the smell issue could cure itself. If the smell returns, remove the air cleaner and inspect the intake tracts for evidence of neat fuel.
Also possible the O rings on the injector bodies themselves can leak, but less likely here as you would see some fuel residue or staining. O rings can be replaced with generics from the local parts store, btw. But if they're not leaking, leave them alone.
Steve Late 2012 M3W
