Morgan Aero 8
5 members (MJF, JohnHarris, Rog, AlyMatt, Plus Four Guy), 249 guests, and 88 robots.
+8Rich 76
DaveW 52
Topics49,868
Posts837,635
Moggo
#685945 30/01/21 11:39 AM
Anyone fitted a bonnet belt on their Aero never been one to run with the sheep, I think I need a tan bonnet belt { lockdown fever}........Em
aerotaff #685990 30/01/21 02:19 PM
Sir S1'a'lot
Sir S1'a'lot
Yeah I think it’s called “lockdown boredom”
That hideously modified Aero that’s been doing the rounds had one. You could go the whole hog and complete all the mods wink
2002 Aero 8 S1
2023 Plus 4 (woman’s)
aerotaff #685994 30/01/21 02:55 PM
Pure bling and a threat to paintwork. Your bonnet will not fly up if fastened correctly. This may not have been the case 70 years ago however.
aerotaff #685995 30/01/21 03:07 PM
Gone past the threat to bodywork stage I quite like the ones fitted to the front of the cowl on the XK120s.......Em
aerotaff #686006 30/01/21 04:08 PM
I've often wondered how secure the bonnet is, particularly at speed. I did hear tell of someone losing a S1 bonnet at speed, a year or so back. Not sure of the damage caused.
David
Aero S4
Barry M #686013 30/01/21 04:44 PM
ahem I can also confirm that your bonnet will not fly up if *not* fastened correctly... did it once by accident. eek.
Will
Formerly Aero S5 #80
aerotaff #686016 30/01/21 05:00 PM
Smile, it confuses them
Agreed, I collected it from a service once and got home to find the drivers side was not fastened. I had done about 90 miles per hour, sorry 90 miles home.
aerotaff #686021 30/01/21 05:15 PM
I can confirm that the whole bonnet can lift up like a bat flying and sail over 2 following Rolls Royce Cullinan's and land behind them :-)
However, it was secured on all 4 knobs. Cause was the bolts coming loose at the front cowl. Recommend you check them from time to time!
Aero 8 GTN. #10
aerotaff #686028 30/01/21 05:32 PM
I had the right bonnet opening at 160 km/h on the autobahn last year. The front lock, which was not perfectly fitting (pre-owner obviously modified the the rest nose), seemed to be over-stressed by the air pressure - luckily, nothing happened, but the front lock needed to be exchanged. This happened after I de-installed the bonnet belt just several weeks before - as slight paintwork damages were visible.
I think when the locks are properly installed / adjusted (I had this done by a Morgan dealer) the bonnets are safe - since, I drove up to 190 km/h without having same problem again. But, if there is too much leeway/movement possible at the locks, the bonnet (which is definitely deformed at higher speeds, as aluminium is soft) might get the necessary millimeters to allow the lock to come off the rest nose - either get it repaired, or use the belt :-) ...
2010 Roadster Sport 3.0 (S3) - black
1997 Mazda MX5 1.6 (NA) - red
aerotaff #686044 30/01/21 07:11 PM
Get a piece of PPF applied where the strap rests. Damage to paintwork problem solved.
Gordon Duguid
