3 members (flyfisher, Graham, G4FUJ, Ritchie B), 240 guests, and 52 robots.
+8Rich 76
Topics49,863
Posts837,547
Page 3 of 5 1 2 3 4 5
Originally Posted by John V6
Inflating the tyres to a higher pressure might help.
I agree inflate the tires to 38-40 and I bet you get the 3cm clearance then once passed have a satisfying deflate.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
tom+4, I agree with others. Before you make expensive changes to the springs, take 65 tires and pump them up good. Any chance you'll have another inspector present at the follow-up?
Try a different MOT station.
Ground clearance can`t be an issue as the car was homolgated like it is.
I have similar discussions with the ecomobile nearly each time. Till now I won them all.
Best one is that the test engineers have to do a test drive with motorbikes and the eco is registered as one.
With the eco the simply can`t;-)
And it is written in the homologation papers that driving on public roads is only allowed after special training.
MOT engineers do not like this part...
1973 2CV AK400 Ralley
1985 plus 4 four seater
1992 Peraves ecomobil
bicycles (pedersen to recumbent)
Originally Posted by RJW
I have just changed the tyres on my plus 4 2013 to 65 aspect ratio in lieu of 60 which is standard for the car with 15inch wheels. This gives more ground clearance (about 10mm I think).
Bob.
Any noticeable difference in handling?
Did you need to recalibrate the speedo?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
RJW Offline
Too early to say on both counts. I’ve only driven the car back from the the garage that fitted the tyres. About 15 miles in the rain but the handling didn’t seam any different. Haven’t driven the car since for various reasons but hope to get behind the wheel in a week or so.
Bob.
Bob.
Thanks Bob. Hope you will be able to update in a couple of months. I expect you will be ok with the speedo as it should only represent about 1 mph at 30.
I am sure there will be others who will be interested too.
Doug
1958 Triton 650
Tom +4:
Have you checked if your car's rear suspension was fitted with Lowering Blocks?
My 4/4 (2011) had them and after I removed the lowering blocks the car had better ground clearance and got better suspension too (my personal feeling)
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
we can choose a station , but when you fail at a MOT station in Belgium , you cannot go to another one. They don't like competition ....
and indeed , with "oldtimers" it became more&more difficult , they always find "something" which means stress and $$$ every year. One of the "new" rules is that everything needs to be original. A car that passed MOT last year , can fail now.... just because they "find" something as a not original seat , yellow shock or red spring ... i also believe it's a policy to get those old cars out of the streets.
I have to go MOT with my '89 +4 .... before "summer" use.... and was also already concerned about ride height problems....IF they inspect it .
2004 GTN #5 sold
1989 Plus 4
CBY Offline
Where is the minimum ground clearance, front or rear, generaly under the curved cross member of the gearbox? For the front, the SSL kit allows to increase or decrease the front clearance and in the worse case for the MOT you can compress temporarily the lower rebound spring and having more clearance.
Regards
2005 PLUS 4
Black Rat
Black Rat
Fit 185x70 tyres
Keith
2013 narrow bodied + 4 Ruby.
