1 members (Bitsobrits), 300 guests, and 36 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 3 of 5 1 2 3 4 5
TBM Offline OP
Originally Posted by John Winn
Have you tried http://www.cover-systems.co.uk/ who are on your doorstep.
They are! Half a mile away. Bit more expensive than John at £195, but I can pick it up!
TBM #685986 30/01/21 01:55 PM
TBM Offline OP
Gone for this one. Like the 'door zip' feature, which allows me to tinker in the cab without removing the whole cover, and pleased to be supporting very local business.
TBM #685987 30/01/21 01:58 PM
TBM Offline OP
Thanks everyone for all the help and advice cheers
TBM #686009 30/01/21 04:19 PM
mal Offline
Our roadster staying indoors with a soft Morgan indor cover.
But I use car covers from Specialisedcovers.com for 3 of my other cars, excellent covers, had them for 3 years now and no issues,, not cheap but well made and do a brilliant job.
This year I splashed out for a system called Premabag, where you drive onto the base of the bag and leave 3 PermaPack® moisture absorbing cylinders under the car before zipping up for the winter. Then using a Thermo-Hygrometer to monitor the moisture
Granted this is not cheap, but no more room in the double garage, and still beats the cost of hiring indoor storage
Mal
3.0 Roadster 2007
TBM #686048 30/01/21 07:26 PM
Black Rat
Black Rat
John Taylor, had mine 7 years still good.
Was it outside? I've had mine two years and it's done,
Spent a year totally outside and 5 years in garage where the top 2' of the side walls was open to the elements. The only problem is other peoples cats using it as a scratch pad !!! Still it does protect my hood from them.
Keith
2013 narrow bodied + 4 Ruby.
TBM #686060 30/01/21 11:45 PM
I bought a Stormforce cover about 6 months back, I had to repair it recently as rubbing across the top of sidelights had virtually worn through the cover.
The screwheads on top of the sidelights are very sharp.
It's usually because someone's used the wrong size screwdriver and nibbled the slot, careful use of a needle file will take the nasty edge off
TBM #686255 31/01/21 10:45 PM
Ray Offline
Put a child's sock on each before the cover. joy
TBM #686289 01/02/21 09:58 AM
Put on a stick on wear pad where the cover meets the sidelights?
TBM #686290 01/02/21 10:01 AM
TBM Offline OP
Get the earlier sidelights - no screws smile
