7 members (JohnHarris, RichardV6, AndyGoff, Image, Cerberas, Aeromax51, Alistair), 312 guests, and 87 robots.
+8Rich 86
Sagging Hood
Topics49,853
Posts837,448
Page 4 of 4 1 2 3 4
planenut #686168 31/01/21 04:04 PM
Originally Posted by planenut
Have you found out what the problem was that caused the smell of petrol yet Ken? It would be nice to know before the whole system gets replaced if you go for Emils "Delux" system.
Nope. So no idea. Since I changed out the lines and clamps, and there’s no sign of fuel other than the smell emanating behind the air cleaner I’m still at a loss. The only insight I’ve gained in this thread I’d that maybe it’s microscopic and coming from the pressed fuel fittings.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
KenShapiro #686181 31/01/21 04:52 PM
Try some UV dye in the fuel?
Late 2012 M3W
Bitsobrits #686833 03/02/21 09:59 PM
Good idea.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
KenShapiro #694982 22/03/21 03:17 AM
The past four or five drives... there’s been no smell. So now I’m really confused as to what cause might be inconsistent.
The Original Ken
11,000 miles.
2014 BMW R9T
2005 Saabaru
2005 Saabaru
KenShapiro #695108 23/03/21 12:42 AM
A leaky injector might give you those symptoms, as the fuel system stays pressurized for some time after shutdown. If the leak was caused by a tiny bit of debris that was later dislodged, the smell issue could cure itself. If the smell returns, remove the air cleaner and inspect the intake tracts for evidence of neat fuel.
Also possible the O rings on the injector bodies themselves can leak, but less likely here as you would see some fuel residue or staining. O rings can be replaced with generics from the local parts store, btw. But if they're not leaking, leave them alone.
Late 2012 M3W
Page 4 of 4 1 2 3 4
