1 members (Doug J),
238
Topics49,844
Posts837,355
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
They are! Half a mile away. Bit more expensive than John at £195, but I can pick it up!
They are! Half a mile away. Bit more expensive than John at £195, but I can pick it up! Gone for this one. Like the 'door zip' feature, which allows me to tinker in the cab without removing the whole cover, and pleased to be supporting very local business.
Thanks everyone for all the help and advice
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
Our roadster staying indoors with a soft Morgan indor cover. But I use car covers from Specialisedcovers.com for 3 of my other cars, excellent covers, had them for 3 years now and no issues,, not cheap but well made and do a brilliant job. This year I splashed out for a system called Premabag, where you drive onto the base of the bag and leave 3 PermaPack® moisture absorbing cylinders under the car before zipping up for the winter. Then using a Thermo-Hygrometer to monitor the moisture Granted this is not cheap, but no more room in the double garage, and still beats the cost of hiring indoor storage
Mal
3.0 Roadster 2007
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
John Taylor, had mine 7 years still good. Was it outside? I've had mine two years and it's done, Spent a year totally outside and 5 years in garage where the top 2' of the side walls was open to the elements. The only problem is other peoples cats using it as a scratch pad !!! Still it does protect my hood from them.
Posts: 84 |
I bought a Stormforce cover about 6 months back, I had to repair it recently as rubbing across the top of sidelights had virtually worn through the cover.
The screwheads on top of the sidelights are very sharp.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
The screwheads on top of the sidelights are very sharp. It's usually because someone's used the wrong size screwdriver and nibbled the slot, careful use of a needle file will take the nasty edge off
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Put a child's sock on each before the cover.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Put on a stick on wear pad where the cover meets the sidelights?
Get the earlier sidelights - no screws
