3 members (Graham, G4FUJ, dakri, Montegue), 158 guests, and 49 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Page 3 of 4 1 2 3 4
Formerly known as Aldermog
They would make wonderful wing mounted sidelights on a Trad!!
Originally Posted by Piloto
If you are interested in a totally cool third brake light, check out the Grimes model B aircraft wing light on Univair Aircraft Supply's website. I dug around my old parts box and came up with one, red lens. I will be installing it on a machined aluminum (or aluminium, depending of your location) mount, and using an LED bulb in place of the incandescent one.
I believe it fits the Morgan quite rightly.
Best,
tom
Those sure are expensive and that flimsy bale might go adrift and another expensive part fall to the ground and break. The general looks is nice.
Very nice looking light. As plain as the Morgan 3rd brake light is, it does accomplish the goal of getting some height. I like having the third brake light, unfortunately the weather is not cooperating so I can get out and enjoy the car. I did while I was messing around with the light yesterday, decided to move the pedals forward to maybe make it where I can get my left leg to relax. That is the easiest adjustment on the entire car.......so far
Everything is higher than the Three Wheeler so unless you want height to try and get above luggage it can easily be seen. Here is a view from the ground, and unless i just ran over you it is a view that never would be seen.
Your third brake light, have you fitted a rapid fire module to it?
It is programmable to how many pulses or staying on or a combination of both.
Thanks for that Lightspeed.
Your light relay seems a good price. The one i bought cost twice as much and only does gls lamps.
I got to looking and the first one i Posted was one i used on a car. This is the one i used on the M3W.
What exhaust do you have on your 3 wheeler?
Page 3 of 4 1 2 3 4
