7 members (KennethM, bmgermany, RubyMog95, JohnHarris, Luddite, TalkMorgan, Mick Annick), 217 guests, and 43 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,081
Page 1 of 5 1 2 3 4 5
I have read that there is some issues with the location of the vent line on the S&S engine. Morgan is using the bottom plug and it has caused blockage? Anyone relocate to the top plug?
Several, look through the past few weeks of Threads tLking about breather lines being plugged.
Even though this is going to a different tank it would work on the stock tank. This is the crank case breather line that goes to the tank
Just in case anyone is worried about the validity of doing this mod, this photo clearly demonstrates that both ports are effectively accessing the same chamber.
Andy
Are you in the magic circle by any chance Andy ?
And for my next trick ....
O
O
I did think about taking the read valve cover off to have a look but you've saved me the bother., well done Andy!
To relocate the fitting to the top as shown one must remove the existing plug. That can be stubborn because it is locttited in solidly. Apply heat to the plug and while hot then unscrew it.
Here's mine I just completed. I just switched the original fittings and shortened the hose from the oil tank to ensure a consistent downward run.
2016 M3W
Was it plugged?
Not plugged but definitely on its way, there was residue in the lowest part of the line. No cooler.
2016 M3W
