6 members (rory kim, Ian Wegg, JMcL, Mats, Mr K, JohnHarris), 339 guests, and 63 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
Page 1 of 5 1 2 3 4 5
#689307 17/02/21 05:09 PM
rcmatt Offline OP
S&S no longer has these and I tried a dealer and just found out it is "backordered".... looks like we are out of luck
Rodger
2004 Plus 8 (wife's)
Personally I’m tempted to just put a few 1.5” holes around the outside of the standard cover. Maybe the 9, 12, and 3 o’clock position (with the 6 o’clock being open from the factory).
Some people have told me this would be a bad idea because of rain but I highly doubt you could get enough in there to cause a problem (heck many modern cars even have water injection to cool down intake temps and act as a natural octane booster). Heck the factory Stage 1 intake is open along the entirety of the outside.
Have you asked Linda at Morgan Spares?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
I think the most important part of this air cleaner is the stinger inside the throat that comes with the cleaner. I bet if you could put that stinger into the stock air cleaner , with maybe a modified can/cover, it would work as well orbetter since the oem cleaner has a larger surface area.
I really like the black muscle cover and was wondering why I could not find it. I was assuming it was a winter issue.
2017 M3W Sport Green
I remember Morgan West used to install the Kuryakyn Mach 2 high flow air filter, but I vaguely remember something about issues with how the weight of the filter is supported. Possibly worth checking out.
This pic is from one of our own, Speedy Marmot’s website.
A Kuryakyn Mach 2 was installed on my car when I got it. It did not have the 'ears' supporting it that attach to the cylinder cooling fins like the above photo. Without the 'ears' the intake will eventually destroy one or the other of the intake runner gaskets at the cylinders and cause air leaks which will throw error codes. Basically the engine vibrates so much and the air cleaner weighs so much that the two try to part ways at the intake runner gasket. Emil makes supports now that fixes the problem if you want to go with a Kuryakyn because you cannot find a Stealth. I replaced my Kuryakyn..... with a Stealth and love it. But I think throttle response was similar between the Kuryakyn and the Stealth.
Thé same of mine
Works well since 2013
I
I
+1
M3W Brooklands (2015)
Moody 41 (2013)
