Topics49,841
Posts837,327
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Good result, we all learn together on here
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Well done Brendan.
You will sleep well tonight.
I'd still be tempted to replace all 3 relays or at least carry a new spare in the car.
The problem if the fan relay fails is that the first you might know is if the temperature goes off the scale and you blow a hose or something equally annoying.
Bob
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
Spare relay...no Mog should leave home without one
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Carry a couple to be sure.
And spare fuses.
What an unfortunate coincidence, diagnosing a faulty reed contact on a family Toyota today, it's spends it's life outdoors and has been used very little, so I suspect condensation corrosion ![[Linked Image]](https://www.tm-img.com/images/2021/02/19/Toyota-sw.md.jpg)
