8 members (JohnHarris, Ncik P, Grumpy2, Moggo, Paulxj, MartinB60, BobtheTrain, ScotiaSteve),
322
41
Topics49,860
Posts837,495
Posts: 153 Likes: 1
Posts: 153 Likes: 1 |
Time has taken its toll from the light switch esutcheon mounted to the front of my Lucas 54334384 rotary light switch. Does anybody know where to get a replacement? Thanks in advance Tim ![[Linked Image]](https://fixingc6622.files.wordpress.com/2021/02/20210218_211842.jpg)
Posts: 37,418 Likes: 977
Posts: 37,418 Likes: 977 |
This place is worth a try, I have just ordered some of the rubber "O" rings for the sidelights from them. If not Melvyn Rutter is worth a try.
Posts: 1,511 Likes: 21
Posts: 1,511 Likes: 21 |
hThere are similar ones on ebay mostly for Jaguars but same lettering.Not expensive Also S.N.G Barratt Light Switch Escutcheon O.S.H.F
Posts: 21 |
Hallo Tim, die Ersatzteilnummer ist C15447. Lieferbar als Aftermarketteil bei http://www.martinrobey.comGruß aus dem Sauerland Günter #Translation# Hello Tim, the replacement number is C15447. Available as an aftermarket part at http://www.martinrobey.com Greeting from the Sauerland Günter
Life is too short to drive boring cars!
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
![[Linked Image]](https://www.tm-img.com/images/2021/02/19/GEDC0098.jpg) If either of these escutcheons are any good I will send one to you, just PM me , not the best but serviceable. Also one is for Fogs and the other for Spots/Driving, so let me know
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 153 Likes: 1
Thank you BrownBaker, Günter and Owen.
I bookmarked both websites - SNG Barrett as well as MartinRobey. SNG Barrett has the 4-position light switch from 120€. Still quite a bit of money for a light switch but much better than e.g. MK Holztechnik Owen - thank you very much for the offer - I will send you a PM
Regards Tim
Hi I thought you just wanted the Black ring? You do not need to buy complete switch.it is about 20 euros . SNG .
