Topics49,866
Posts837,587
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Sounds like what was called a leaking diod in the alternator. had it happen in the +8 .recon alternator cured it.
Posts: 9 |
Hi, Thanks for all information , problem solved now, Atlernator checked and OK/ belt tension checked and OK/ made new wiring from alternator to starter OK/cleaned ground cable from engine-gearbox to frame OK/ no poor/weak light from battery check lamp OK/ voltmeter now needle is almost to the maximum OK best regards and safe Morganeering.
Posts: 28,900 Likes: 352
Posts: 28,900 Likes: 352 |
Good news! Thanks for the update
Posts: 27,814 Likes: 749
Posts: 27,814 Likes: 749 |
Agreed. Glad you solved it.
