3 members (James B W, ScotiaSteve, JohnHarris), 250 guests, and 63 robots.
+8Rich 83
Topics49,860
Posts837,497
Jonny72
Page 4 of 4 1 2 3 4
It looks under the dash to me, standard motorsport battery isolator. Remove the red key to isolate.
Neat job, looks like factory fit.
Originally Posted by PaulV
Interestingly I had to boost my Lithium battery after a few weeks. It claimed a charge but not enough to turn the engine over... maybe the wet sumping added too much load? Paralleling my old (and by itself defunct in terms of M3W starting) Banner (technically only 2yrs old, but swapped out last year) got it started.
Possibly I have an "electrical leak" somewhere. Only outstanding electrical issue is that the heated seats havent worked since I put the insides back together again last year... probably I should pull the fuse!
If it was cold, ie below about 5c then lithium batteries need to get warmed up first. Leave the headlights on for about a minute and prime the fuel two or three times. The starter may still churn for 20 -30 seconds before anything fires but it will get there.
If the engine has significant wet sumping then you'll need to drain some oil from the engine and put it back in the tank then all should be OK.
Red Leader drive
Originally Posted by M3W55
As a matter of interest, with your skills why did you not fit the isolator key under the dashboard rather than having to take the hood off every time?
As Dab of Oppo observed, it is under the dash, near the steering column. Easily accessed when standing beside the car, or when sitting in the drivers seat. But pretty much invisible to the casual observer, especially when off or with the key removed.
BTW- my bonnet is center hinged, so getting underneath it would not be a chore at all.
Late 2012 M3W
Sorry - of course it is. Old age.
I
I
I use a Varta 53030 30ah. It fits and has the same terminals as the Banner and does a good job but I do keep it on a conditioner when the car is in the garage.
M3W Brooklands (2015)
Moody 41 (2013)
Wilson how are you getting to France? You cannot take Lithium batteries through the tunnel unless fitted to a vehicle. Probably OK on a ferry but best check?
Thanks Steve, that switch install is exactly what i had in mind.
And i would it if you could post photos of your split bonnet and how you did it. Do you have a link?
Interestingly I had to boost my Lithium battery after a few weeks. It claimed a charge but not enough to turn the engine over... maybe the wet sumping added too much load? Paralleling my old (and by itself defunct in terms of M3W starting) Banner (technically only 2yrs old, but swapped out last year) got it started....
Good tips Chris. Will try the headlight tip next time it happens (next Winter?). Never been able to drain much oil from the sump, and 8 secs max gets it firing after a spell of inactivity.
Thinking I might tackle the heated seat switches from underneath if there is room (mine has no plate under the propshaft, and I suspect road spray could have shorted the connections as I did not reapply the original generous covering of duct tape over the wiring!!!).
PaulIV,
My heated seat connector that takes the switch wires and connects them to the fuse panel area is under the fuse panel close to the battery. Darn hard to access.
Page 4 of 4 1 2 3 4
