Topics49,858
Posts837,463
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
As the horn on a Mog is so rarely used they sometimes spring back into life with a little hammer tap whilst applying voltage
Posts: 1,415 |
If you’ve still got the original vertical radiator in the car, then you’ll have no problems getting to the horn fixing nut and bolt with out having to remove the grille
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
If you’ve still got the original vertical radiator in the car, then you’ll have no problems getting to the horn fixing nut and bolt with out having to remove the grille But not if you've got a nice shiny Sifab radiator fitted
Bob
Posts: 46 |
Many thanks to you all. Finally managed to crawl underneath with a meter this morning. Confirmed that the horns knackered. New one on the way.
