0 members (),
320
32
Topics49,904
Posts838,088
Posts: 120 |
Help from Dubai again, mechanically i can figure most things out, white mans magic is a black art to me, here is the problem. My indicators, to be precise front right, has stopped working, the other 2 right hand indicators, right wing and right rear are working but blinking faster than normal, all left side indicators working normally. The bulb is fine, no visible damage to wiring, all relays and fuses healthy. for you electrical officianados out there, please educate me.
thanks
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS Triumph Thunderbird 2000 Volvo XC 60 x 3 Volvo C30
Posts: 28,911 Likes: 354
Posts: 28,911 Likes: 354 |
I would suspect a defective earth connection for the failed indicator Steve. The other two flashing fast is a built in indication that there is a failure on that side. Good luck with finding the duff connection
Posts: 120 |
Maybe a visit to an auto electrician is called for? I assume one of those 2 headed monsters will some method of locating and repairing the fault.
Steve Grisdale
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
I wasn't aware that electrics were the preserve of white skinned males..? Shame, as I have a great contact with someone who doesn't fit your 1970's attitude.
Still, good luck.
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
I expect it isn't a damp issue in Dubai. To get at the earth remove the UK drivers side front wheel. Remove the nut where all the wires go to & clean it. Can you rig up a bulb & connect one end to the power to the indicator and the other to ground? That will show if the earth is the problem.
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
Try the bulb. A failed bulb causes the others in the system to go faster. Is there water inside the lens? That causes corrosion and shorting. If ok check the earth. Also, MMC use bullet connectors and the ones under the front wing are VERY exposed to road spray and can corrode. I have had similar symptoms to you twice. Rear indicator poor earth, found by doing a wiggle test of wires under the rear arch where they go through to the lamp. The riveted connection inside the lamp had worked loose. Front bullet connectors replaced by spades with shrink wrap to seal. Water inside as well, used the “drill a drain hole “ solution!
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
Have a look at the power wire to the center. Of the back of the bulb, mine pulled out of the fiber ring and wasn't touching the bulb.
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Have you checked bulb is working elsewhere when you say it's fine?
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Have a look at the power wire to the center. Of the back of the bulb, mine pulled out of the fiber ring and wasn't touching the bulb. +1. It happened to me once.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 681 |
I wasn't aware that electrics were the preserve of white skinned males..? Shame, as I have a great contact with someone who doesn't fit your 1970's attitude. Nicely put. I must admit the thread title was a bit of a shock. Let's be honest, a missing apostrophe is a serious matter.
