Topics49,860
Posts837,497
Posts: 27,811 Likes: 749
Posts: 27,811 Likes: 749 |
Stainless is vunerable to stress crack corrosion from chlorides such as road salt. Not a good choice in my opinion.
Posts: 8,672 Likes: 410
Posts: 8,672 Likes: 410 |
Tensile strength is generally reduced with stainless bolts which is the main concern when used to replace high tensile bolts. Commonly available A2 (304) stainless has barely half the ultimate tensile strength of grade 8 or 8.8 high tensile steel and yields with even less.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Stainless on stainless may cause galling. If it does the only way to remove them is by cutting them off
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
As above don’t use stainless. It would be safer with new high strength bolts rather than standard bolts. You could also use a thread locking method. Even Loctite liquid would add a decent extra security.
