Topics49,918
Posts838,258
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
Just a quick question guys.
How is everybody stopping the crank shaft from rotating when tightening up the front pulley bolt?
I slackened it off using a windy gun and don't really want to put it on the same way. S&S tell us to use so much loctite that we could probably get away with doing it up finger tight!
Andy
Posts: 488 |
Certainly be fun getting it apart again, blow torch required me thinks!
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
Thanks Rog, I'll give it a go this afternoon.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
When you are using the kit with the dowel pins to properly locate the cam position don’t rely on those alone, the belt can slip a notch, had it happen because I didn’t have it in gear. I thought i had put it in gear with the e brKe on but I forgot and it slipped a cog or two when I was torquing it in place. PITA.
All sorted.
I left the dowel pins in and slowly torqued up to 60lbft. I thought it was going to bend the pins but didn't.
Afterwords I turned the engine over a few revolutions with the crank pulley nut (no spark plugs or battery in), to see if it all still lined up.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Mine wet sumped during lockdown last year and leaked oil, seemingly, from the rear crank oil seal. I'm struggling to get underneath it to confirm but the Factory tell me that it won't self heal and it's an engine out job to replace. Anyone had any similar experience?
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
The rear crank oil seal actually seals on a spigot extending from the Centa outer. There are two potential problems, there are often marks on this spigot from the chuck when the assembly was machined, and its diameter is 50mm whereas the seal is for a 2 inch shaft (50.8mm). The way to fix this is obviously a new seal and install a Speedy sleeve on the spigot. Speedy sleeves are used to repair damaged shafts and will also increase the diameter slightly, although not up to 2 inches.
Phil Bleazey fitted a 2" sleeve to a 50mm splined adapter which was having its centa upgrade done. Might be worth having a word with him
Andy
Quick update on the new oil seal.
Had the engine up to temp a few times and drove it up and down the drive ( not taxed as yet) so no road test, not a drop of oil has come out so it look like it is sorted.
An added bonus was on initial starting it always to 3 or 4 revolutions to fire up but not this time less than 1 revolution it fired up perfectly. I just wonder if the old cam belt was 1 tooth out so the timing was not spot on.
Who knows.....
Posts: 2,243 Likes: 73
Posts: 2,243 Likes: 73 |
Did you have any problems removing the old seal in situ? How did you do it in the end? I don't think your engine would have run as well as it did if a cam was a tooth out, I have followed you 😉.
