1 members (Pyewacket), 226 guests, and 38 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 5 of 5 1 2 3 4 5
I rerouted my new downhill vent line to the other side of the transmission, detouring as it leaves the tank.
This avoids going over the top of the transmission, is more direct , shorter and only gets near hot things right at the end.
I see. you went through the front higher than I did. Maybe this weekend I will look at doing that.
Rodger
2004 Plus 8 (wife's)
Over the steering rack i believe.
Yes, I went over the rack as well.
Rodger
Thats right , over the rack. Going under looked to make the final section a bit flat compared to before the rack, defeating the object.
Threading it this way was as close as I could see to making a continuous gradient.
I put an air hose at the end close to the oil tank and blew out a small amount of oil/water mixture. It was a few spoons full of white cream.
Mine is a 2017 with about 4k miles.
The white creamy froth is normal to all internal combustion engines. It's a mixture of water and frothy oil. It's just that most engines don't have long external vent lines with a 'droopy' low level loop to collect the stuff.
Late 2012 M3W
