4 members (britmog, BobtheTrain, vbalddave, Socalm3w), 281 guests, and 56 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
Page 4 of 4 1 2 3 4
Originally Posted by John V6
I think the dampers use the same mounting point
No John , the dampers are inside the coil over units. I will have to check whether these mounting points are used at all now.
Andy G
1999 +8 , Indigo Blue.
All good choices.
The sump should be #1.
Also consider anti tramp bars & upgrading to new rear suspension hangers bolted to the rear drums.
MMC upgraded the hanger design as it can fail. Mine failed on one sided after spirited touring down to Naples & Sorrento. I had it welded up then replaced both sides.
Here is the parts book extract. Look at item 4.
Here is the upgraded design with shoulders to the plate
Here is the typical failure of the old design.
Thanks for that, luckily the car has SSL 5 link with coil springs so I don't think this is applicable?
No its not , well done for buying this Mog !
Are they direct from MMC or available via a dealer?
Don't worry Yanto, the 5 link is completely different & uses a much more substantial lower mount as below
Sorry Yanto seems I misled you.
John sorry no idea but if you take out the tool tray you can easily see what you have. Then while you are there spray the leaf springs with bike chain lube.
Page 4 of 4 1 2 3 4
