Posts837,937
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
What year did MMC redesign the chassis to eliminate cracking Nd bump steer? Not bolt on mods but a complete new chassis coming out of the factory..
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Good Question LightSpeed. Doesn't the parts and modification document added to the M3W section in this forum cover that.....? https://www.mtwc.co.uk/wp-content/uploads/2020/07/Final-150.pdf
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
What year did MMC redesign the chassis to eliminate cracking Nd bump steer? Not bolt on mods but a complete new chassis coming out of the factory.. Mid-ish 2014 onwards as far as I am aware, constructed using improved materials too it seems - and probably better made all round. Also supplied with a newer design of suspension upright that raised the steering mount points to have the same alignment as the Comfort Kit 'upgrade' that was previously avaolable.
Posts: 8,693 Likes: 414
Posts: 8,693 Likes: 414 |
Two separate issues I think Stephen. The bump steer being largely reduced but not completely cured by the addition of MMC's sarcastically named "comfort kit" which brought the track rod angle from steering rack closer to horizontal when static. This was offered early in production as a short term fix for early models, later corrected by different uprights which achieved similar. Most other changes/improvements including chassis took place late in 2014 when the NVH kit was introduced, with chassis upgrade kit also becoming available.
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
What year did MMC redesign the chassis to eliminate cracking Nd bump steer? Not bolt on mods but a complete new chassis coming out of the factory.. Mid-ish 2014 onwards as far as I am aware, constructed using improved materials too it seems - and probably better made all round. Also supplied with a newer design of suspension upright that raised the steering mount points to have the same alignment as the Comfort Kit 'upgrade' that was previously avaolable. I suspect that the factory also produced some hybrid chassis used for replacing those in early models that were cracked - our M3W is a very early 2012 example and the replacement chassis has the hard bolted (no NVH) bevel box and a front geometry that uses the very early Suplex shocks with a comfort kit that retains the low ride hide but better steering arm geometry and of course all the bracing...
Posts: 1,671 |
What year did MMC redesign the chassis to eliminate cracking Nd bump steer? Not bolt on mods but a complete new chassis coming out of the factory.. Mid-ish 2014 onwards as far as I am aware, constructed using improved materials too it seems - and probably better made all round. Also supplied with a newer design of suspension upright that raised the steering mount points to have the same alignment as the Comfort Kit 'upgrade' that was previously avaolable. I suspect that the factory also produced some hybrid chassis used for replacing those in early models that were cracked - our M3W is a very early 2012 example and the replacement chassis has the hard bolted (no NVH) bevel box and a front geometry that uses the very early Suplex shocks with a comfort kit that retains the low ride hide but better steering arm geometry and of course all the bracing... Agreed - I was also told my MM it was a Hybrid chassis (2014/15) which replaced the early 2012 cracked one - they then replaced the body hence MOGster is a fairly unique 2012 with 2015 Hybrid chassis and 2016 body complete with louvred tail.
Thanks for the good info guys, much appreciated. And i did forget to look through the mtwc publications, thanks again.
This is very illuminating, thank you for reminding me about it.
This is very illuminating, thank you for reminding me about it. This is an excellent "live" document which I think would be very useful to M3W owners
Posts: 338 Likes: 1
Posts: 338 Likes: 1 |
Ian Morgan Family 1929 ( KTW 1100cc ) Morgan S/S 1934 Morgan F4 M3W 2012 Morgan +4 T 1991
