Topics49,901
Posts838,046
Posts: 39 |
Any suggestions for simply and fairly painlessly accessing an ignition switched power supply on my 2015 car? I need a power supply for extra instruments. I keep the car charged by plugging a Ctek into factory the accessory socket under the dash, not sure whether this will make things more complicated. All suggestions very welcome.........
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Heated seat supply maybe if its unused ![[Linked Image]](https://i.imgur.com/gBEtBcZ.gif)
Posts: 101 |
RichardV6 has a good idea. If you do have seat heaters, you can use an "add a circuit" " in the seat heater fuse location.
Scott
2018 M3W 1995 Porsche 993
Posts: 39 |
The seat heater circuit sounds good, and I do not have heated seats so the circuit is unused. The fuse board has wiring connected from No 20 fuse (5A) and disappears into the loom. According to my fuse board legend this is for the heated seat circuit. I am wondering if tails exist under the transmission tunnel ready to connect to the switches installed when heated seats are fitted at the factory ?
Had not thought of the fuse location addition, so thanks for that suggestion. All options are open!
Yes the wiring schematic shows a pair of cable tails with individual bullet connectors in that location. These could be drawn back and re-routed towards rear of dash if unused.
Posts: 39 |
Many thanks to all for the help, I now have something to work with.
The forum is such a great resource.............
