Topics49,861
Posts837,529
Posts: 7 |
Hi to everyone, my aero MK2 has some ABS issues. The warning lamp comes on occasionally. We tried to detect the fault with a Busch scanning tool, but unfortunately it does not connect to the ABS module of the car. Anyone has any idea which exact ABS system Morgan fitted to the aero's, or faced similar problem? Thnxxxx Zsolt
Posts: 15 |
Hi
Have you checked the ABS clips aren't corroded i had that issue on my S2
Posts: 7 |
Hi, thnxxx I will give a look🙏
Posts: 11,529 Likes: 312
Posts: 11,529 Likes: 312 |
I have a warning on my S2 concerning the rear brake ABS sensors when it went in for it's last service. It might be a similar issue, listen for a road speed related click/ping noise from the rear axle if it is this.
On the rear drive shafts the sensor rings have small lobes which go past the sensor to give the pulses it uses to measure the rotation. These rings are a tight fit over the drive shaft near the wheel hub. The issue is with the ring expanding or working lose over time and so the lobes clip the sensor. You hear a click/ring sound which changes with road speed from the back of the car.
Apparently these are the same as BMW 1 Series and it is a common problem on those cars. Fixing it will be a fairly simple job, either new drive shaft or if they are interested in manual labour then they can swap new rings onto the existing shafts.
If this has been happening for some time the sensor can become misaligned and generate an error. The engineer told me to get them swapped soon. Since then I have not even been able to use the car so that's a pain waiting to get fixed along with the rose joints on the rear suspension.
Posts: 7 |
Yesss, I've heard some rotating noises, so this might the problem, thanx for the info...
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
I dont know whether this is relevant at all since I cant remember the car that it related to. But apparently in some cases you get corrosion between the ring and the part of the hub its attached to which causes the ring to split but stiil to remain. This truggers alarms. Certainly check the rings.
Posts: 7 |
Thnxxxx Howard i will do it
