Topics49,850
Posts837,427
Posts: 305 |
Yesterday I noticed a small pool of coolant under the car ,checked all hoses and found nothing . Took the car for a 20mile run and on my return found a small weep of coolant from the top hose . Tightened the jubilee clip and added a second one .I then checked every jubilee clip every one tightened a little bit . I didn't overtighten . Something else worth checking .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 120 |
Hi does your radiator have a plastic connection for the small pipe from the coolant header tank?
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS Triumph Thunderbird 2000 Volvo XC 60 x 3 Volvo C30
Posts: 305 |
Hi Steve .no plastic Its a SIFAB radiator , that is one of my best mods as I didn't trust the plastic factory one .
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Very cold weather causes contraction of metal pipes which can cause minor leaks. I struggled with one on my Roadster for a couple of winters.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Me too Dave (better use +1). Though I did find regular checking of the jubilee clips also helped. Now I have a plastic one I worry about over tightening
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
I think I may be going waterless...  ![[Linked Image]](https://www.tm-img.com/images/2021/03/23/20210323_122034.jpg)
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 37,412 Likes: 977
Posts: 37,412 Likes: 977 |
Oh I thought you meant you were getting an M3W for your work car.. then I spotted the leakage..good luck.
