7 members (Julian BB, Grumpy2, Graham, G4FUJ, GrumpyPa, Plus Four Guy, TeddyAds, Joske Vermeule), 399 guests, and 88 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,759
Originally Posted by 2Sharp
Anyone use the VREDESTEIN Quatrac? Tire rack has them.
The Quatrac is Vredestein's Grand Touring All-Season tire developed for the drivers of coupes, sedans and station wagons looking for good dry and wet performance combined with confident light snow traction. The Quatrac meets the industry’s severe snow service requirements and is branded with the three-peak mountain snowflake (3PMSF) symbol.The Quatrac features an all-season tread compound molded into a distinctive, directional, v-shaped pattern. Larger outboard blocks increase dry road cornering along with a connected center element helping maintain handling and steering response. The resulting large, open grooves effectively evacuate standing water for increased hydroplaning resistance and combine with two types of sipes for confident control in wet conditions. High-density siping and numerous off-angle blocks create the biting edges needed to provide light snow traction for stability in wintry weather conditions.Internal construction of the Quatrac features twin steel belts for strength and durability, along with a single ply casing and reinforcement for comfort and high-speed stability.
Looks like a nice tire. Tire Rack is my yardstick for tires and they tend to be spot on. I have used them for years in judging tires, but obviously the M3W is not in their range of products.
I switched to this tire at the beginning of last season mainly because I was looking for a decent wearing but higher traction option. No issues to report. Shortly after installation I discovered the Vredstein Classic Sprint which I think I will try next time.
Other than wet pavement performance, I don't think these machines will be very sensitive to rear tire choice given the inherently mismatched front/rear wheel/tire combination they come with.
Late 2012 M3W
I don't know how many of you drive your M3W in the snow (I certainly do not) but if that's what floats your boat then DO NOT use this tire. My neighbor had this tire and had a disastrous winter.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Originally Posted by britmog
...I don't know how many of you drive your M3W in the snow (I certainly do not) ...
I am now imagining skis under the front wheels and a track around the rear for a kind of M3W snowmobile... wink
I like the way you're thinking laugh2
Scott
2018 M3W
1995 Porsche 993
I thought about it certainly would be novel but decided to stick with my real snowmobile which is dangerous enough snow cold sos
Bruce
2013 M3W (Olga)
Thanks for all the comments guys. As someone pointed out, the Parts List identifies a number of tires that are not available to us Americans, or not in the size necessary. I cannot wrap my head around using a snow tire year round because, well, I will never drive my M3W in the snow but I will drive it in good weather. Staying with my desire to put a symmetrical tire on the car I was able to find a few options. Looks like I might go with the Kumho Ecsta PA31 which has symmetrical tread, a V speed rating, good treadwear, and is an all-season performance tire. Seems to hit all the necessary requirements. But the Vredestein Quatrac is tempting also. Hmmm.
It’s a common misconception that all-season tyres are “for when you might drive on snow or ice”. They usually have good rain-use support, but are better thought of as “low temperature conditions” such as found in alpine driving - even when there is no snow or ice. In Norway or Switzerland they are probably a no-brainer M3W choice. In the UK probably a bit of a compromise but not much. In Florida likely not needed wink
JMD Offline
Two key criteria for a tyre are
1) A rubber mix defined for good grip in the expected temperature range - true "summer" and "winter" tyres operate best in their design ranges - summer tyres are too hard in the cold and lose grip - winter tyres are too soft when hot and may not grip ideally and can wear badly. Cross climate tyres use a compromise compound that works well in temperate climates and also appeal to SUV users
2) Tread design - lots of blocks and/or channels help water dispersion to prevent aquaplaning and help grip in snow/mud - so winter tyres have lots of blocks/cuts - these blocks move around and get hot when going fast so winter tyres are often speed limited. Cross climate tyres have tread designs closer to winter tyres so are often good for wet grip/aquaplaning.
Our M3W (like many others) has a cross climate on the rear for confidence on wet grip - on our Boxster we go all the way with 2 sets of wheels for summer/winter. Suspect in our climate neither get tested to the limit but on this kind of safety issue, caution is good.
However, biggest concern for me is usually the way people run their tyres all the way to (and beyond) the 1.6mm legal tread limit let alone to the typical 3mm wear indicators...this has biggest negative impact on wet grip/aquaplaning - we usually change well before the wear indicators and this also ensures the tyres are not too old (5-6 years seen as max recommended as rubber hardens over time)
