8 members (jbk, Pittsartist, Luddite, RichardV6, PaulV, Davetherave, Sir Percival, JoeSpeetjens), 293 guests, and 93 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,457
#695006 22/03/21 09:51 AM
jimmyw Offline OP
Yesterday I noticed a small pool of coolant under the car ,checked all hoses and found nothing .
Took the car for a 20mile run and on my return found a small weep of coolant from the top hose .
Tightened the jubilee clip and added a second one .I then checked every jubilee clip every one tightened a little bit .
I didn't overtighten . Something else worth checking .
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
jimmyw #695023 22/03/21 11:28 AM
Hi does your radiator have a plastic connection for the small pipe from the coolant header tank?
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS
Triumph Thunderbird 2000
Volvo XC 60 x 3
Volvo C30
jimmyw #695032 22/03/21 01:18 PM
jimmyw Offline OP
Hi Steve .no plastic Its a SIFAB radiator , that is one of my best mods as I didn't trust the plastic factory one .
Jimmy
2018 VW Tiguan
jimmyw #695056 22/03/21 03:48 PM
Very cold weather causes contraction of metal pipes which can cause minor leaks. I struggled with one on my Roadster for a couple of winters.
jimmyw #695063 22/03/21 04:32 PM
Me too Dave (better use +1). Though I did find regular checking of the jubilee clips also helped.
Now I have a plastic one I worry about over tightening
jimmyw #695222 23/03/21 08:06 PM
I think I may be going waterless... redcard
06 Saab 93
Oh I thought you meant you were getting an M3W for your work car.. then I spotted the leakage..good luck.
