2 members (jim109b, linklaw),
296
Posts837,990
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
The door cards on mine are held down with the plug/pins along the bottom edge and to get them out you need to get under them and pull them like a thumb tack or drawing pin away from the door frame. To do this you need a v-claw shape but one that spreads the load. The dealer had one of these as they do it often. I am afraid I do not have one.
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
If somebody decides to dismantle the panel, please a few pics of the process. I'd really be willing to do it (and maybe replace the speakers) but I am not so brave without a proper visual guide.
Posts: 378 |
Thanks all for the responses. Ale- can you point me to where the diagrams are located please? Kevin - those items on Amazon look worth a punt! If not the chisel is at hand! Thanks T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Ale- can you point me to where the diagrams are located please? Easy! https://www.aero-racing.co.uk/partsbooks/supersports/main_menu.htmPlease a few pics, if you tear down the door panel!
Please excuse this - not meant in a rude manner as other people will have more experience than me. Just trying to share what I watched on mine being taken apart. The tools you highlight are not what I would use having seen the dealers tools. They are exactly the pointy things that will rip the leather due to the pressure area compared to the force needed. The items I watched in use were far wider to spread the load. So looking in the Amazon pool I suspect it was the part in the top right corner with a thin cut made down from the top centre to let it straddle the pin. https://www.amazon.co.uk/BQTQ-Pieces-Removal-Retainer-Installer/dp/B08DFN7WB6Also the little pins often die on engagement so it's helpful to have some spares. Morgan wanted £3 each for them!
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
No offence taken Alistair. My old S1 panels have been off a few times in 20 years so they don't need much persuasion to come off! The tools you highlighted look much more substantial and I think I'll order a set for myself.
I think the SS panels will be a much different piece of kit to take off and those may be a better option for that.
Posts: 336 |
My old S1 was indeed Fiesta Mk4 regulator and gubbins, but the cables were not. From memory we made up new Bowden cables and used a new Fiesta part when my passenger one failed.
Removing the door card was easy when you found the hidden screws, and access was easier in the door than I thought as well.
Posts: 378 |
Hi Alastair I have all the door trims off (phew!) but where do you manually wind it up? many thanks T
Posts: 378 |
Hi Ale In the middle of stripping it down but can I ask you to send your e-mail as I am hopeless in posting on the web site Many thanks Peter
