9 members (Robbie, B3MOG, JMcL, gazum, +8Rich, High Hamster, Paulxj, MJF, DCH), 256 guests, and 53 robots.
+8Rich 75
Topics49,863
Posts837,554
#696765 01/04/21 03:01 PM
O
Old man Offline OP
O
I live in Belgium and here we have had 95 E 10 petrol for 6/7 years. Within the last few months 3 zetec engined cars have suffered fuel pump failure, all 3 ran 95 E10. To change the pump is not easy or cheap. The E10 attacks some rubber hoses and gaskets.
Old man #696799 01/04/21 06:05 PM
As I understand it automotive rubber, nitrile butyl rubber, which is resistant to petrol is also very hard. It has to have a plasticiser added to make it supple enough to use but ethanol added to E5/E10 fuel cheletes the plasticiser. Consequently the rubber becomes brittle and cracks/fails. It is important, therefore, not to have rubber at all and use silicone but many older cars have NBR components.
This is as I understand it but it may be that a Talkmogger will correct me if I am wrong!
Old man #696800 01/04/21 06:14 PM
Felix correct. Newer cars have different compounds. There are many threads on this on here. From memory cars after 2010 are OK.
Old man #696813 01/04/21 07:07 PM
In the Netherlands Shell Vpower has NO ethanol, so that is what I always buy. So this is the best alternative to E95. In th UK it may contain up to 5% of ethanol. In NL i stick to Shell V power, I want to avoid any ethanol induced trouble and I like the extra perfotmance. Also CO2 is set off wt V power.
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
