6 members (RJW, mph, Colin_Mackay, nestor59310, TalkMorgan, jbk), 251 guests, and 29 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,259
Smed., Spanner Juggler
Page 3 of 4 1 2 3 4
Originally Posted by Dab of oppo
Just a quick question guys.
How is everybody stopping the crank shaft from rotating when tightening up the front pulley bolt?
I slackened it off using a windy gun and don't really want to put it on the same way.
S&S tell us to use so much loctite that we could probably get away with doing it up finger tight!
Andy
O
O
Certainly be fun getting it apart again, blow torch required me thinks!
Thanks Rog, I'll give it a go this afternoon.
When you are using the kit with the dowel pins to properly locate the cam position don’t rely on those alone, the belt can slip a notch, had it happen because I didn’t have it in gear. I thought i had put it in gear with the e brKe on but I forgot and it slipped a cog or two when I was torquing it in place. PITA.
All sorted.
I left the dowel pins in and slowly torqued up to 60lbft. I thought it was going to bend the pins but didn't.
Afterwords I turned the engine over a few revolutions with the crank pulley nut (no spark plugs or battery in), to see if it all still lined up.
Mine wet sumped during lockdown last year and leaked oil, seemingly, from the rear crank oil seal. I'm struggling to get underneath it to confirm but the Factory tell me that it won't self heal and it's an engine out job to replace. Anyone had any similar experience?
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
The rear crank oil seal actually seals on a spigot extending from the Centa outer. There are two potential problems, there are often marks on this spigot from the chuck when the assembly was machined, and its diameter is 50mm whereas the seal is for a 2 inch shaft (50.8mm). The way to fix this is obviously a new seal and install a Speedy sleeve on the spigot. Speedy sleeves are used to repair damaged shafts and will also increase the diameter slightly, although not up to 2 inches.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Phil Bleazey fitted a 2" sleeve to a 50mm splined adapter which was having its centa upgrade done. Might be worth having a word with him
Andy
Quick update on the new oil seal.
Had the engine up to temp a few times and drove it up and down the drive ( not taxed as yet) so no road test, not a drop of oil has come out so it look like it is sorted.
An added bonus was on initial starting it always to 3 or 4 revolutions to fire up but not this time less than 1 revolution it fired up perfectly. I just wonder if the old cam belt was 1 tooth out so the timing was not spot on.
Who knows.....
Did you have any problems removing the old seal in situ? How did you do it in the end? I don't think your engine would have run as well as it did if a cam was a tooth out, I have followed you 😉.
Page 3 of 4 1 2 3 4
