0 members (), 332 guests, and 85 robots.
+8Rich 77
DaveW 52
Topics49,867
Posts837,614
Page 4 of 6 1 2 3 4 5 6
Originally Posted by Chris99
I beleve the Brooklands exhaust is less restricted than the stock one and close to the MMC stage 1.
Easy to check at night or in a dark garage. Once warmed up let the engine idle for a couple of minutes and see if the headers glow red. If they do then it is a bit restrictive, if they don't then you should be OK.
Thanks! I haven’t noticed them glow after a run but I haven’t specifically looked either.
Thank you!
Forgot to ask where you picked up the intake? Thanks for the help.
I went a bit of a complicated route on it to get the look I wanted. I wanted Stealth kit + 1” taller filter + Air Stinger Filter + Stealth Cover Ring. The Stealth kit is all that is functionally needed. I wasn’t able to find the Stealth cover ring so I ended up buying x-wedge stealth kit, 1” taller filter, and Harley air stinger kit (which has both Air Stinger Filter + Stealth Cover Ring) and now have extra parts I can’t use:) The 1” taller filter is a drop in replacement if you already have the stealth kit. You just need to make sure you get the threaded standoffs which extend out the holes so that the cover can be attached; accounts for the 1” additional height. The one I link to below has the standoffs. Here’s where I got everything:
Stealth kit
1” Taller filter
Harley Air Stinger kit. Looks like they are out of stock on it. You could pick any of the ‘Air Stinger Stealth Kits with Brushed Aluminum Ring’ from this list here if you want the same look.
Thanks again.
You've got yourself a sharp looking Three Wheeler there, i haven't seen a polished bodied Morgan. Love to see some more photos of it.
Thanks again.
Ok, you inspired me to do a photo session. Out of respect to this thread, I created a new thread and posted them there. Link below and a preview.
Photos
Interesting call on tire 👍🏼. Makes total sense . I just bought a 2017 M3w. 2000 miles great tread on rear tire. Should I be concerned? Due to tire age alone ? Replace it ? Thanks. U seem to be up on stuff.
Very very very special and nice ride . I bought a 2017 Burt orange 🍊 M3w last month .
Good stuff.
Tyres (tires) should be replaces at about 5 years old regardless of tread so you should be OK for this season but I'd change them next year.
Definitely put some sort of puncture sealant in the existing rear unless you as certain it's already been done. I use Puncturesafe but I'm sure there are similar products available in the USA
Red Leader drive
Stealth kit
1” Taller filter
Thanks really like your air cleaner set up. I went and ordered the same parts. 2001-2017 Harley-Davidson Big Twin w/ Cable Throttle (NO TBW) Part Number: SS170-0716
Seems like a better way to get air into the throttle body.
2017 M3W Sport Green
