1 members (CraigL), 342 guests, and 57 robots.
+8Rich 95
John V6 52
Topics49,897
Posts838,017
Hi there.... long time....
Having just revived my 87 Plus 8, my garage is reporting that my Lucas 4 ECU fuel control unit 83986B is lacking an ignition signal.
I would very much appreciate a recommendation for a company to repair that please.
Also - having fitted a wider exhaust, though the car runs within MOT specs, I can taste fuel in my mouth. Perhaps an ECU tweak might help?
With many many thanks in advance,
1987 Morgan Plus 8
Is your fuel injection "Flapper" (13CUX) or "Hotwire" (14CUX)? I think I have a fault finding manual for the latter , but not for the former.
Andy G
1999 +8 , Indigo Blue.
Does Russell @ Revolutions have any contacts he can share with you ?
Maybe worth a trawl through this .
I notice there are some units for sale on fleabay but they have an "A" suffix and I have no idea how or if that is significant.
Hi Paul
Give Derek a ring at Turriff Auto Electrical, he worked with Lucas until they shut up shop. He might be able to help you out. A Google search will bring them up.
Gordon Duguid
Thank you for your replies (and private message). very much appreciated...
MOG 615, its a flapper PRC4764 i'm afraid.
1987 Morgan Plus 8
Paul, does the engine start and run? The ecu as far as I can remember gets its signal from the distributor, the ignition side (ie spark) is separate from the ecu which is only for fuelling, try taking the ecu apart and re-soldering the transistor connections they usually show cracks in the solder (dry joint). If all else fails I have a complete set of parts for the flapper from my car that I kept when i changed the lucas system for something modern and more efficient (as well as full fuel and ignition mapping) PM me.
David Byrne
Paul, quick correction the ecu gets its signal from the coil. sorry for the mistake.
David Byrne
