Topics49,911
Posts838,147
Posts: 39 |
Went for a lengthy blast in my 2015 M3W to enjoy some sunshine. Fabulous as always. When I arrived home and the car stopped moving I was clearly able to smell 'something hot'. I found my rear wheel/ brake was very hot indeed, and when I went to push the car into the garage it was hard work as the rear brake was obviously dragging. I have seen the numerous previous posts on the Forum regarding rear brake issues,and was not looking forward to having to remove the whole assembly to resolve the problem. Fine as a Winter job, but I want to use the car in better weather !
Luckily, I made a chance phone call to Phil Bleazey( such a pleasant person and incredibly knowledgeable) regarding one of his upgrades, and mentioned my rear brake problem. He immediately suggested simply changing the brake fluid before doing anything else.
I changed the fluid, flushing plenty through in the process, and the result is a total success. No binding and all is as it should be.
I suggest that if anyone else has a similar problem just try a fluid change first and foremost. It worked for me.
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
Might be a warning of corrosion on the pistons which can prevent them from retracting, your fluid flush is good practice every two years anyway BUT your cure will be temporary. It's a known issue with 4 wheelers which use the same rear cylinders
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Agreed Jon. You can peel back the boots on the pistons as use the correct grease to help reduce the risk as well.
Posts: 39 |
Thanks for that, I hope it will work until the next Winter job list is in operation !
Standing idle over winter is the worst thing for brakes, hopefully plenty of summer use will help, if you don't use the Mog much, my tip is to just jump in every week and pump the brakes & clutch a few times
Posts: 492 Likes: 11
Posts: 492 Likes: 11 |
For those with experience, is part of the problem sitting in the winter with the parking brake engaged? Does the parking brake engage the front, rear or all 3 brakes?
I do have a problem with one of my newer cars, if the barking brake is engaged after a run in the rain, they sometimes stick and have to break free with a bit of motion when I next start it up.
Thanks
Craig - Texas, USA 2026 Plus Four 2021 M3W
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
Went for a lengthy blast in my 2015 M3W to enjoy some sunshine. Fabulous as always. When I arrived home and the car stopped moving I was clearly able to smell 'something hot'. Hi Mr M. Wheel, If you haven't already seen it there is a lot of useful rear brake info in this THREAD.
Andy
Posts: 1,947 |
A whack with a rubber mallet might be a temporary fix for a sticking rear brake. Red rubber grease inside the exposed cylinder under the boot is likely to help.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Thanks that has happened with the wife's plus 8. She couldn't back it out of the garage. I had to "pop it loose" as it were.
