1 members (+8Rich),
281
35
Topics49,911
Posts838,149
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Yes I do. Just run the pump by turning the ignition on and it should show the regulated pressure on a gauge at the test point and hold pressure for a few minutes. It will dissipate over an hour or so. If you have a super "Emil style" fuel system I am told the pressure drops off almost immediately the pump stops but the standard Mahle type filter/regulator should hold pressure for some time.
Sounds like Emils system is a more safe system. Who needs fuel pressure after and emergency shutdown from a fire!?!
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
I don't think it is a safety issue but just the way the pressure regulator works. I am sure the regulator in Emils system regulates the pressure more accurately than the Mahle filter /regulator but the Mahle one has to comply with it's OEM specification that says it has to hold pressure after supply stops for a time, probably because most engines fire up quicker than the X-wedge if they stall. I imagine it is easier to regulate a constant leak rate than to hold a pressure when the supply is gone, particularly for a combined filter and regulator that is a throw away item built to a price of about £40. Agreed that in our installation there is no need for the system to hold pressure for any length of time but most of these filter/regulators do just that.
Posts: 51 Likes: 2
Posts: 51 Likes: 2 |
Anyone know what the correct spark plug gap is for the M3W I just changed my champion RA8HC plugs. One was set at 28 and the other at 30. I put in NGK DCPR7EIX and out of the box they are 28. I put them in as out of the box 28. I dont see any difference between the two. Seems to start the same and took it for a short drive. All seems normal. My old plugs only had 3300miles but I read on a face book users page that the NGK plugs help with starting. My old plugs still look good so will keep them as spares.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Anyone know what the correct spark plug gap is for the M3W I just changed my champion RA8HC plugs. One was set at 28 and the other at 30. I put in NGK DCPR7EIX and out of the box they are 28. I put them in as out of the box 28. I dont see any difference between the two. Seems to start the same and took it for a short drive. All seems normal. My old plugs only had 3300miles but I read on a face book users page that the NGK plugs help with starting. My old plugs still look good so will keep them as spares. Same for me Thé only big difference is the price
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
I think with the big fat spark of modern electronic ignition systems, spark plug gaps are far less critical than they used to be. Obviously for Raphy and me running our S&S engines in a hot climate, where cylinder head temperatures get quite high, especially if using the original baffled exhaust system (my cylinder head temperatures dropped over 40ºC by changing to G56 non-baffled exhausts), resistance to thermal erosion is an important consideration on the plugs and that is why I use Iridium plugs. I would think Bosch platinum plugs, like Porsche recommend for their turbo engines, would be equally good.
Wilson
