1 members (Socalm3w),
291
Topics48,341
Posts812,981
Posts: 22 |
Wow what a fabulous response from you all, I'd not received them all when I replied to headless b. Thank you
Midget, sprite, spitfire, TVR Tuscan 2500 (was my fav.) stag, <2 kids> 2015 Morgan 4/4 sports red
Posts: 4,607 Likes: 192
Posts: 4,607 Likes: 192 |
Welcome to TM and to Morgan ownership Alwlo, I guess in the time you spent researching matters Morgan, that you found GoMoG. com, if not then should you decide to beam it up you will find access to all sorts of Morgan related information. Of course there are loads of helpful friendly folk here who are more than happy to try to help out should you want a more local answer to any question you might have on your Morgan.
Posts: 22 |
Cheers John I'll try that
Posts: 22 |
Hi Phil, I'm a comer inner, only been here 35 yr, Dobcross first 15 yr then Uppermill, used to enjoy a pint in the Navi most Friday nights
Posts: 2,062 Likes: 57
Posts: 2,062 Likes: 57 |
The bonnet opener on my 4/4 are very strong! I had to find out wich one to open first.. I also had to glue the handle from the passenger sidescreen with superglue -after searching for this part over a distance of 200m
Posts: 887 Likes: 28
Posts: 887 Likes: 28 |
welcome to TM and many happy miles with this super new car!
1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Posts: 22 |
Oops, wrong car info given, it's a 2015 yr, me and my iPad sausage fingers. Can any body help me , I would like to put a photo with my profile, I have been into the edit window but still not sure how to . Cheers
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
Cheers headless b, couple of cries for help if anyone can ! 1) first day the Perspex window button came off, before I stick it back using superglue, am I using the correct adhesive/method ? 2) front passenger side bonnet fastener will not open, I mean it's rock solid, any suggestions please . Spray some wd40 where you can over the catch then force down till open. Then oil or grease until free movement on the slider.
Posts: 28,415 Likes: 177
Posts: 28,415 Likes: 177 |
Welcome to TM! When opening bonnets undo the rear catch first, then front. When closing lock the front catch before the rear. No doubt it is a front catch that you cannot open? A little pressure against the bonnet may ease things. Morgan moved the front catches further forward on later cars, which can make them seem very stiff. As for photos - put them on a photo hosting site, then provide a BBCode link to insert the photo into a post. ( www.tm-img.com is a good hosting site, set up for TM members - there is an Instructions for Use page), If you are adding photos into a photo section on here directly, because you are using a "fruit" product, you will need to edit the file name extension to remove the "e" from .jpeg Good luck with photo posting! And, enjoy your new car
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 22 |
Thanks again to everyone for the welcome and advice, to many post to reply to individually, but all much appreciated. What a good site this is, it's reassuring just knowing it's there
