3 members (RedThree, Morganmike, SailingTom2), 232 guests, and 27 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
Isn’t there an automatic adjustment mechanism inside the rear brake drum that must be released when reassembling the drum over the shoes?
Yes, you can see the serrated pawl at around 10 o'clock, just below the lettering Y47
Is there a special tool to release it on the car to facilitate drum removal?
BTW, thanks for the photo.
No, but you can fit a manual brake adjuster to make the job easier in the future! Check out this
THREAD.
Andy
Thanks Bunny.
Can't be seen in the photo but externally there should be an oval shaped rubber grommet you can remove, then just pop in a small screwdriver and just ping apart the pawl, it's spring loaded to retract and back off the shoes...job done !
Thanks Jon.
