12 members (IcePack, John V6, Chris Cosher, Gonze, Alan Patterson, Ian Wegg, DickJ, RedThree, MartinB60, sprinty, GrumpyPa, bmgermany), 303 guests, and 95 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 20 of 25 1 2 18 19 20 21 22 24 25
That and the single black roll bar make it look so low and sleek.
Same with the unfinished welds noted on the frame fishmouth tubing. If I tried to pass that through my FAA inspector, he would flunk me and possibly report me to the aviation authorities.
TN
Airframe and Powerplant licensed mechanic.
O
O
Agree but not so much when someone is sat in it.
Originally Posted by Obie
Good demonstration why the term “roll bar” is somewhat optimistic. Maybe “headrest hoop”? wink
It's ok, your body below is soft so your head retracts out of the way as you invert grin2
It does look a bit higher and certainly not so safe, says he with a Plus 8 where the only thing higher than your head is the weak windscreen frame all part of the joy of ownership. That black helmet suits it..
Between the height of the rollbars, and the fixed P101 wind deflectors, if you have very quick reflexes, you may have just enough space to safely duck under the protection of the P101 touneau cover in the event of a rollover. Then, you can use your equally quick reflexes to escape from the interior space just before the vehicle catches fire. Thus this is a perfectly safe design in the event of an emergency!
If not, as Jay Leno points out, the Morgan 3 Wheeler is perfectly coffin shaped. There won't be a more stylishly ensconced corpse in the cemetary!
Craig - Texas, USA
2026 Plus Four
2021 M3W
Very good laugh2 , having watched a few getting in and out of these flying machines I am just hoping and praying nothing untoward happens.
Originally Posted by Bitsobrits
The zipper holds the drivers side to the passenger side, which has the liftthedot studs.
Is the driver's tonneau rigid otherwise what keeps the lower edge in place? Would the rigid tonneau fit in the boot?
