5 members (Morganmike, Pipmac, rossocorsa, JohnMat, RichardV6), 373 guests, and 107 robots.
+8Rich 80
DaveW 52
Topics49,866
Posts837,607
#701383 01/05/21 05:16 AM
Hi anyone know where I can get a wash wipe stalk or compatible ones such as triumph? The usual places such as Ritter seem to only have indicator stalks
I don't there are any new switches to be had, if you do find one it will be very expensive compared to an indicator stalk, which I find strange because the indicator switch is a more complicated item. However it is the same switch as used on the Triumph Dolimite which are advertised secondhand regularly
Dolimite wiper switch
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
TBM Offline
Try eBay
Wash Wipe
TBM #701386 01/05/21 05:40 AM
Try eBay
Wash Wipe
I'm afraid that's a different swich
Owen
"bilibib"
bilibib #701387 01/05/21 05:47 AM
TBM Offline
Try eBay
Wash Wipe
Easy to adapt though if not bothered with originality. I've used an indicator switch from a mini - bit of fettling and rewiring, but over £100 cheaper than OE.
I would still use an original model switch, because generally I think you will find a lot these copy switches are of a very flimsy construction, the contacts are thin, the moldings are poor, all in all a bit rough and lightweight
Not that Lucas were ever the best.
Owen
"bilibib"
TBM Offline
Mne was not a 'copy', original Lucas from a different model so came without the 'Morgan Mark Up' price. Most of the time, the only difference is the plug on the end. I cut the plug off my old, and spliced it onto the new.
Rimmer have several 'OE' wash wipe stalks in stock, and again it appears the only difference is the plug on the end. Couple of minutes with a wiring diagram and a soldering iron and job done.
would help if we knew what year and model of Morgan you have?
Arwyn
Arwyn
I assumed it was a 1985-87 Plus 4
Owen
"bilibib"
bilibib #701631 02/05/21 06:13 PM
That’s great thanks
