7 members (+8Rich, Alistair, IcePack, ScotiaSteve, Player99, Burgundymog, MATTMOG),
156
64
Topics49,864
Posts837,576
Posts: 32 Likes: 2
Posts: 32 Likes: 2 |
Hi anyone know where I can get a wash wipe stalk or compatible ones such as triumph? The usual places such as Ritter seem to only have indicator stalks
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
I don't there are any new switches to be had, if you do find one it will be very expensive compared to an indicator stalk, which I find strange because the indicator switch is a more complicated item. However it is the same switch as used on the Triumph Dolimite which are advertised secondhand regularly Dolimite wiper switch
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
Hi anyone know where I can get a wash wipe stalk or compatible ones such as triumph? The usual places such as Ritter seem to only have indicator stalks Try eBay Wash Wipe
Posts: 287 Likes: 8
Hi anyone know where I can get a wash wipe stalk or compatible ones such as triumph? The usual places such as Ritter seem to only have indicator stalks Try eBay Wash WipeI'm afraid that's a different swich
Hi anyone know where I can get a wash wipe stalk or compatible ones such as triumph? The usual places such as Ritter seem to only have indicator stalks Try eBay Wash WipeI'm afraid that's a different swich Easy to adapt though if not bothered with originality. I've used an indicator switch from a mini - bit of fettling and rewiring, but over £100 cheaper than OE.
Posts: 287 Likes: 8
I would still use an original model switch, because generally I think you will find a lot these copy switches are of a very flimsy construction, the contacts are thin, the moldings are poor, all in all a bit rough and lightweight Not that Lucas were ever the best.
Mne was not a 'copy', original Lucas from a different model so came without the 'Morgan Mark Up' price. Most of the time, the only difference is the plug on the end. I cut the plug off my old, and spliced it onto the new.
Rimmer have several 'OE' wash wipe stalks in stock, and again it appears the only difference is the plug on the end. Couple of minutes with a wiring diagram and a soldering iron and job done.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
would help if we knew what year and model of Morgan you have?
Arwyn
Posts: 287 Likes: 8
Arwyn I assumed it was a 1985-87 Plus 4
Posts: 32 Likes: 2
