7 members (Saxonian, Eastertown, Paul F, Mark+4, CRL, Carbuilder, Burgundymog), 176 guests, and 98 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,878
Posts837,753
Page 3 of 7 1 2 3 4 5 6 7
Rog #702497 08/05/21 12:28 PM
Lecat Offline OP
Thank you for your support.. and all the useful contacts.
I have tried to compare the boards but haven't a clue about what numbers or letters are significant, so I will have to get some help with that. They look very similar but your previous posts suggests I should be cautious.
I have a few contacts here in Sweden and I'll have to wait and see what they can come up with. In the meantime I will actually try to talk to Power Torque and see if they can give me a hint of where to go next. Mark Baldwin sounds interesting too...
Compared:
https://drive.google.com/file/d/164qBhDtalvdGK4sj0RBPLM9kTHT19vsq/view?usp=drivesdk
https://drive.google.com/file/d/1659ByNu5Jwy3VBdZW_v53zGvW7mOnfng/view?usp=drivesdk
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat #702500 08/05/21 12:52 PM
Did you have a chat with the guys at ATP in England?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Lecat Offline OP
Not yet Bob, but I will speak to (with?) them and to 'ECU Decoding' next week now that I have some more coherent and relevant information to share with them.
I appreciate all the help I can get, thanks.. englandwave
Lecat #702544 08/05/21 05:58 PM
Rog Offline
Those builds do look very similar thumbs
I don't think anybody has done this before here on TM with a Zetec. Watching with interest....lurk
Roger
Lecat #702551 08/05/21 06:58 PM
On a different note but a similar vein, I wanted to play with my Zetec and I felt I was going to be restricted by the ability to tune the ECU mapping so I stripped all the Morgan / Ford wiring out and put in an OMEX stand alone ECU.
Not completely straightforward but it does allow you to adjust the mapping very easily as you modify the engine or in my car swap the engine altogether.
Another benefit is that you can get rid of the immobiliser completely which is not required by UK insurers on a Morgan provided it's garaged overnight when at home.
Not suggesting it would be your first choice but it is very satisfying when you do get it right.
Bob
2009 Black Roadster
Lecat #702556 08/05/21 07:23 PM
Bob, I did a similar thing with my 85 +8inj. I removed the lucus ecu, coil, distributor injectors etc. and fitted a Canems mappable system that controls the fuel and ignition. Future proof and reliable.
David Byrne
Lecat Offline OP
Actually Bob... I've had half-an-eye on the Omex for quite a long time. Everybody seems to be very happy once the job is done. I guess it's not something you do over a weekend... though I have taken out and repaired a complete ECU loom from a Citroën BX GTi 16V once. Given the right circumstances... and the time... and the place... Worth considering if the current project grows out of proportion. Thanks for reminding me smile
... I guess it's a bit tricky to do all the wiring from scratch... thinking
Lecat #702638 09/05/21 01:28 PM
Rog Offline
Originally Posted by Lecat
Searched the net earlier in the week and strangely enough I found a used Escort 1.8 Zetec EEC IV ECU
Just a wild thought…. Whilst rummaging around in a copy of Autodata today I took a quick look at a late 1.8 Escort 60 pin ecu.
Is there any chance that you might have say, taken out the small 3 amp fuse suppling pin.1 of the ecu? (the ecu would still get a supply from the main from the 20 amp fuse).
Roger
Rog #702642 09/05/21 03:05 PM
Lecat Offline OP
I like wild ideas crazy2
I have checked but couldn't find any 3 amp fuse. Where is it supposed to be located if not among all the other fuses. Are there fuses somewhere else... blush
Lecat #702647 09/05/21 03:38 PM
Rog Offline
On a Duratec and going by memory I think it’s the second fuse (LH side) in the 8 slot fuse holder screwed to the bulk head (engine side). And mine is a 20 amp fuse! It’s the fuse that also keeps the ecu awake to retain the memory when the ignition is off and powers the immobiliser led.
Roger
