9 members (High Hamster, Strathaven, JMcL, AlyMatt, JohnHarris, Zach, Beard, nick w, Barkbark), 406 guests, and 84 robots.
Sagging Hood
Topics49,859
Posts837,470
Page 2 of 4 1 2 3 4
Sifab offer 30mm stainless bobbins Rob. 54mm stainless U clamps here.
ETA: no mention of the bobbins Craig used as being stainless!
Richard, my replacement Bobbins and U clamps are not stainless, I only used stainless spring washers. The new Bobbins are polyurethane and not rubber bushings either. I understand polyurethane generally last the life of whatever vehicle they are on ? while rubber Bobbins might need to be replaced multiple times depending on environmental factors and how many miles are accumulated.
I might consider changing the U bolts to stainless though, if I can get them in 54mm and 58mm ?
Craig Jezz
My Google Fu is obviously stronger than you lot.....
shiny bits
More shiny bits
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
When I replaced the clamps on mine a while back I lightly brushed some copper grease over them to see if it would give some protection. I’ll give them a check sometime.
Rog Offline
Love the colour Craig love
Just check the PU doesn’t suffer from heat conduction from the cat.
Roger
SimonH #703280 14/05/21 12:38 PM
shiny bits
More shiny bits
Excellent - thank you.
Costock, UK
Disco 5
I've found the bobbins issue is not the rubber or even the bond of same Craig. As the rust takes hold it creeps under the bond so rubber becomes free to break away with rust still attached!
Great work Craig thumbs
If anyone wants OE looking black poly ones they are sold by Mini Spares at around £3 a pop
That’s good news then Richard, I don’t want to run out of jobs, it will keep me busy in my man cave replacing them again.
Craig Jezz
SFG Offline
Very nice. Shame they're so out of sight normally! smile
No, you can see them !
SFG
2012 4/4 Sport
Absolutely, and here wink
Good opportunity whilst in this area to cut off excess thread on bobbin studs to increase ground clearance. Ditto seat bolts.
Page 2 of 4 1 2 3 4
