1 members (Saxonian),
261
73
Topics49,849
Posts837,424
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Sifab offer 30mm stainless bobbins Rob. 54mm stainless U clamps here. ETA: no mention of the bobbins Craig used as being stainless! Richard, my replacement Bobbins and U clamps are not stainless, I only used stainless spring washers. The new Bobbins are polyurethane and not rubber bushings either. I understand polyurethane generally last the life of whatever vehicle they are on ? while rubber Bobbins might need to be replaced multiple times depending on environmental factors and how many miles are accumulated. I might consider changing the U bolts to stainless though, if I can get them in 54mm and 58mm ?
Craig Jezz
Posts: 1,415 |
My Google Fu is obviously stronger than you lot..... shiny bitsMore shiny bits
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
When I replaced the clamps on mine a while back I lightly brushed some copper grease over them to see if it would give some protection. I’ll give them a check sometime.
Posts: 1,703 Likes: 35
Posts: 1,703 Likes: 35 |
Love the colour Craig  Just check the PU doesn’t suffer from heat conduction from the cat.
Roger 2011 Plus 4
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Sifab offer 30mm stainless bobbins Rob. 54mm stainless U clamps here. ETA: no mention of the bobbins Craig used as being stainless! Richard, my replacement Bobbins and U clamps are not stainless, I only used stainless spring washers. The new Bobbins are polyurethane and not rubber bushings either. I understand polyurethane generally last the life of whatever vehicle they are on ? while rubber Bobbins might need to be replaced multiple times depending on environmental factors and how many miles are accumulated. I might consider changing the U bolts to stainless though, if I can get them in 54mm and 58mm ? I've found the bobbins issue is not the rubber or even the bond of same Craig. As the rust takes hold it creeps under the bond so rubber becomes free to break away with rust still attached!
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Great work Craig  If anyone wants OE looking black poly ones they are sold by Mini Spares at around £3 a pop
Sifab offer 30mm stainless bobbins Rob. 54mm stainless U clamps here. ETA: no mention of the bobbins Craig used as being stainless! Richard, my replacement Bobbins and U clamps are not stainless, I only used stainless spring washers. The new Bobbins are polyurethane and not rubber bushings either. I understand polyurethane generally last the life of whatever vehicle they are on ? while rubber Bobbins might need to be replaced multiple times depending on environmental factors and how many miles are accumulated. I might consider changing the U bolts to stainless though, if I can get them in 54mm and 58mm ? I've found the bobbins issue is not the rubber or even the bond of same Craig. As the rust takes hold it creeps under the bond so rubber becomes free to break away with rust still attached! That’s good news then Richard, I don’t want to run out of jobs, it will keep me busy in my man cave replacing them again.
Craig Jezz
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Very nice. Shame they're so out of sight normally!  No, you can see them ! ![[Linked Image]](https://tm-img.com/images/2021/05/14/A9012A1F-3440-45C0-9907-E16796FA5419.jpg)
SFG 2012 4/4 Sport
Absolutely, and here  ![[Linked Image]](https://i.imgur.com/P628gBL.jpg) Good opportunity whilst in this area to cut off excess thread on bobbin studs to increase ground clearance. Ditto seat bolts.
