Topics49,904
Posts838,083
Posts: 20 |
1998 Plus 4
Hi, there is a button in a rubber case on the left upper edge of my bulkhead by the wiper motor in the engine space. I can't upload a picture of it, but I want to know what it is before I press it. Thanks
Graham 1998 Plus 4 Red 1986 Land Rover 90 Muddy
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Sound like the inertia cutout reset switch.
If you have an accident or hit a massive pothole etc it will cut out the engine and fuel pump to prevent a fire.
You have to press the button to reset if it goes off when it shouldn't have done.
Can't be sure without photo but that's what it sounds like
Bob
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
It is an inertia cut off switch for the fuel supply. Switch
Posts: 990 |
Sometimes can trigger when you hit a very big pothole or bump ( cuts off fuel in accident/collision situations) - resets by pushing on the top.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
Posts: 20 |
Perfect answer. Now I know what it is, I hope I never need to use it.
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
If you ever have a need to run up oil pressure without firing the engine, it can be a simple way to do so if you give it a smart tap with something to trigger the mechanism, then just push the button down to start as normal. Also a simple way to test it works!
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
