Topics49,858
Posts837,465
Posts: 8,671 Likes: 408
Posts: 8,671 Likes: 408 |
But I wonder if the kit adapts the calliper so that the bleed nipple is on the top? Depends on caliper design but it's sometimes possible to swap the balance pipe between caliper halves and bleed nipples end to end as threads are usually the same.
Posts: 665 Likes: 31
Posts: 665 Likes: 31 |
The top of a bolt fixing the lower suspension arm was hitting the brake calliper when the wheel was at the maximum.
As it is a floating brake the part moved a little and the brake pads where not in contact with the disk.
The same bolt has been reversed to avoid contact and now it is ok.
Posts: 1,127 |
 ...but good they found the fault in the end!
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
