Topics48,362
Posts813,331
Members9,215
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Would a tiny wipe of epoxy on the serrations help when fitting ? Very probably - and/or a smear of copaslip on the threads. I tend to do this anyway as I usually use stainless fasteners into the rivet and want to avoid differential corrosion.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
They are good for lower load applications but a small dab of locking fluid/ JBWeld adds security. A light smear of a grease like copper based stuff and stainless bolts adds to a better life. You can build up a nice stock of stainless bolts/screws etc quite cheaply. I use them to replace older fixings whenever needed. Car/ garden house etc. A2 grade is ok or A4 if needed. Never on high stress safety fittings though. Haven’t used rivnuts for a long time but if set correctly they are handy. Easier than tapping holes.
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
Rivnut is good for me the best tool is this one ![[Linked Image]](https://zupimages.net/up/21/21/290j.jpg) there are all kinds of different on the last photo they are crenellated they can be mounted with loctite 638 for bonding.
Posts: 1,562 |
Blimey GLLOQ , I see the problem is with me .... gets coat.
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
I had the same thought!  We are lucky indeed to have the world's foremost proponent of rivnuts on this forum!
Andy
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
I would love to have a video of these fine tools being used down in the footwell on the transmission tunnel cover.
