1 members (Saxonian), 261 guests, and 73 robots.
+8Rich 81
Topics49,849
Posts837,424
#704690 26/05/21 04:33 PM
John V6 Offline OP
A "source" told me today the fix is to reverse the calipers so n/s to o/s but upside down. Then they only squeal going in reverse. Is that true? It seems a very MMC solution
Yes it is true,but there is a kit
Spanner and bottle of Dot 4 [Linked Image]
John V6 Offline OP
And maybe new decals on the calipers? Or maybe you need slightly different pipes
Dont know if it's due to the kit but two times my brake pedal went to the bottom just after starting up the engine
John V6 Offline OP
I think I would be calling the dealer ASAP.
If the calipers are turned upside down, and the bleed nipples are then at the bottom, bleeding becomes harder.
But if the pedal drops on starting the engine, it also suggests the servo is causing that effect. Maybe some air still in the system.
Whatever is going on, it needs looking at.
But I wonder if the kit adapts the calliper so that the bleed nipple is on the top?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
I have found it occurs only when the wheel is turned at the maximum at slow speed ( 1gear).
Same max left or max right.it was not there before the correction for the squeal.
Tomorrow the garage will check with a plus four with the modification. If i release the wheel
A little the brakes come back.
John V6 Offline OP
It could be I guess a trapped pipe on full lock.
