5 members (Black Adder, sewin, Davetherave, TBM, rossocorsa), 104 guests, and 19 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,261
Smed., Spanner Juggler
Page 1 of 5 1 2 3 4 5
#707824 24/06/21 05:01 PM
I would like to fit a clock does anyone know how easy it is to find the prewiring
Thank youbehind the dashboard - does the dash have to come out? ( hopefully not)
Gilberto #707832 24/06/21 05:57 PM
Hi Gilberto
The was wiring is already in place in my car, it was just plug and play. Most difficult part is making sure you drill the hole in the dash in the correct place.
Some pics here.
Craig Jezz
Gilberto #707836 24/06/21 06:27 PM
Remove the 2 screws either side of the dash and centre screw and you will see the cable tie which needs to be cut where the clock wiring is attached to the rev counter bracket. You might be able to access by removing the underdash panel but probably easier to remove the 3 screws and support the dash on a towel on the steering cowl.
Photo is looking down from the top of the dash
Rob
Gilberto #707839 24/06/21 06:39 PM
Sorry if pedantic and absolutely no criticism intended. It should be obvious but, to the uninitiated..., Craigs super helpful photos show the flap wheel to clean up the hole prior to the one drilling it with the hole saw.
Also Rob’s advice: on mine, to remove the dash for access, I would also have to remove the series of little screws that attach the undertray to the edge of the dashboard, as well as the three main securing screws.
Doug
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Gilberto #707843 24/06/21 06:44 PM
Europa spares do a lovely clock which fits in well with the Morgan dash - battery powered and sticks on. No drilling, no wiring. Battery lasts a couple of years and easy to change. About £40 I think. Suits those of us with a Yorkshire mindset.
PhilRoyle #707845 24/06/21 07:23 PM
I went through two of those in 3 years Phil, kept stopping, went through multiple battery’s so I gave up & fitted the Smiths clock.
Craig Jezz
Deejay #707846 24/06/21 07:27 PM
Doug
I apologise Doug, the pics were not sent in the correct order. The clock was a tight fit after drilling the hole, so I sanded the hole (Mdf) with the sanding wheel until it was a nice snug fit
Craig Jezz
Gilberto #707849 24/06/21 07:41 PM
Yes Craig, I did the same with flap wheel due to tight fit.
Incidentally, just like you, I also had the same experience with the battery powered clocks. Worked fine until I changed the battery then kept stopping. Bought another and same experience!
Doug
1958 Triton 650
Craig Jezz #707855 24/06/21 09:17 PM
Cheers
Many thanks
Gilberto #707859 24/06/21 09:57 PM
One tip..if you are going to use a hole saw it’s best to ‘score’ the dash surface first by using it in reverse in the drill. Less chance of the teeth digging in.
2008 4/4 1.8 Duratec
