Topics49,918
Posts838,261
Posts: 44 |
Plucking up courage to have a go at the dash in the meantime put my hand up behind the dash and found what appears to be a metal box on the far right in the corner - any ideas what this may be? Also had a quick look underneath behind the dials but can’t easily see any clock wires are they likely to be easily located? Sorry for being a pain but I’m a novice at this but would like to try!!,
Posts: 44 |
Don’t appear to have a screw in the cente!
Posts: 27,855 Likes: 767
Posts: 27,855 Likes: 767 |
There could be 2 screws slightly off centre. What model is your car?
Posts: 44 |
2005 Plus4 can see screws either side of dash but doesn’t appear to be anything else
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
2005 Plus4 can see screws either side of dash but doesn’t appear to be anything else My clock wiring was attached to the rev counter bracket with a cable tie. I have a 4/4 so it might be different on the plus 4
Craig Jezz
Posts: 44 |
Thanks will see what I can find must be there somewhere!
My 06 Roadster had 4 screws. 2 obvious at the edge near the doors & 2 close to the centre of the dash. They ar high up & you may need to put your finger between the dash leather roll & the dash to feel them.
Posts: 44 |
Thank you will see what I can find!
Posts: 44 |
Thanks to all connections now found just hole to drill!!
Posts: 44 |
Hi everyone now have the clock in place fits great! Don’t seem to have enough clearance for the bulb holder- any ideas please?
